I just went over to Auto zone and got some paint....painted the screws so you cant see them at all now. I just wanted to be sure that the lip doesnt sag when im driving on the highway, doing 70-80mph. It just seemed like it would sag, since it was used, i expected alittle sag in it. I know it would of been worse driving down the highway as the passing air would of been pushing down on it. Also, wanted to be DAM sure no one is able to steel it without some major work. Same thing with the back...it seems that its a tad bit warped right around where the exhaust comes out. I couldnt get it to mount right without putting some screws through the bumper and lip. I couldnt do it on the bottem sides, cause it doesnt sit flush there, only in the middle where the first screw goes. This is also bad because it pushes the lip farther up in the middle, making it look like it bent upwards, so i didnt use that screw for that reason.
I dunno if tape will hold up under florida weather. I only drilled a 7/16th hole in my bumper, its hardly noticeable at all.
I think i might end up painting my front/rear bumper and the side skirts. I prob would get the gaps filled with bondo and remove the screws.
