What's the difference between lowering springs and coilovers?
-helloimD4NNY
I've been looking at others' cars and some use lowering springs others use coilovers. I recently bought a 2002 EM2 a couple Wednesdays ago and plan to lower my car soon so this will influence my decision of lowering springs or coilovers.
DeathLens
EM1 Crew
you can adjust the height with coilovers
lowerings springs... you're pretty much stuck with the height you end up with
Mr. Jollypants
Mr. f**king Jollypants
Lowering springs are exactly that, they just lower your ride height by a set amount, but give you a harder ride.
To do it the right way, you'll also replace your shocks.
Coilovers give you the ability to change dampening settings, adjustable ride height.
If you go with CHEAP EBAY coilovers, you're going to pay for it by a hard ride and shitty suspension. Go the right way, get Tein's or Form and Function's.
Coilovers are the way to go, no doubt about it. The extra cost is offset by the abilities to setup the car the way YOU drive.
purpej1
honda fiend
it all depends on what you want. whats the budget if your dd'ing the car or what. lowering springs is exactlly what their called springs that lower the car. Bad thing with springs is your stuck at what ever height it settles at. coilovers are adjustable wich is good for snow to summer weather and if your not happy with height. coilovers imo come in two types the cheap sleeve type people tend to call them coilovers even tho the proper name is adjustable springs. And the full body coilovers wich are pretty pricey but yet very affective and rewarding afterwards.
i wrote this whole thing to see their was already like 3 replies when i was done fml.
Mr. Jollypants
Also:
NOT COILOVERS
These are adjustable springs.
COILOVERS
These are proper coilovers.
R3dline
function and form type 1's ftw
SisterFister
ok not to thread jack but its what the hell is the difference between shocks and struts?
I also plan on gettin suspension on my car, this is my set up, skunk2 sports shocks and Blox racing lowering springs, is this a good set up?
FlipSkater079
If you get lowering springs + shocks you'll be set. As long as you don't need to adjust anything. But coilovers gives you the ability to change height and many other things. Depends what you want, and what your price range is.
