What's wrong with my turbo!!!!!!!!!!!!!!!!!!!!
el_betiyo
Ok, so my mechanic finally put my 18g greddy turbo in my car. Everything look and ran fine, untill smoke started to come out of the turbo. Not that much, just a llitle bit and smell like burned oil. So, we're thinking that the turbo is burning oil. The turbo was used and the guy that sold it said that it ran fine. But no. My mechanic told me that I can still run it like that and just be checking the oil level like everyday or so, and once I save some money to rebuild it. So, any comments guys......................
bizoneoeh
Ex-Gang Member
If I were you, I'd just buy another one instead of having it rebuilt. How much did you pay for it anyway?
jdm98coupe
JDM H22A with LSD
sounds like blown seals, usually turbos will smoke like hell from burning oil because the seals are blown/bad. but yea i would recommend just buying a new turbo, by the time you rebuild that turbo, you could just buy a brand new one.
el_betiyo
18g turbo, manifold, downpipe, boost/air-fuel/oil pressure gauges, 255 fuel pump, oil fed-return lines. $450
el_betiyo
Well the smoke is not exactly coming out of the seals of the turbo from what we can tell. Since there's a small gap between the downpipe and the exhaust pipe, from there is where we beleive the smoke comes out. I'm taking the car to this exhaust shop to weld it today. We check that yesterday but it was very late, so I still need to be sure. My engine though, before didn't throw any smoke, so it's not the engine.
Matt.
did you use a paper gasket? Chances are its burning up, what does the smoke smell like?
el_betiyo
BLAHMAN240 It smell like burned oil, don't know how to explain the smell.
RYAN89CRX oil restrictor?, don't have a clue bro, I have to talk to the mechanic about that.
How bad is it gonna get if I leave it like that? or should I rebuild it, I mean the kit to rebuilt a turbo is like $70, so what should I do? a new turbo?
ryan89crx
Spoolin single cam!
install an oil restrictor if you dont have one and see if the smoking goes away. its actually harder to "blow" seals than you think. for the most part, when you fix you over pressure problem, the seals will still work fine
oil restrictor - in line orifice that restricts oil as to lower the pressure. OEM Honda oil pumps put out 60+ psi of pressure, and the standard bushing-type turbo only needs about 10-25psi of pressure
d16_turbo
does your return line have a kink in it ???? if it does that will make the oil blow by the seals too
jdm98coupe
JDM H22A with LSD
yea rebuild kits are cheap to by but to get a professional shop to do it properly is where its gonna cost you a good amount haha. but idk just get it checked out and let us know.
el_betiyo
d16_turbo What do u mean by kink? Sorry, I'm new to this turbo thing...........
d16_turbo
its not hard to do it yourself. i rebuilt one of my turbo's. the expensive part is if you have to get it sent off to get balanced but if you mark the wheels and put them back on exactly how they came off it won need to be rebalanced
el_betiyo
like pinched not letting oil go back into the oil pan
I'm also checking that today.
Thanks guys for the suggestions, I'm on my way to my mechanic and I'm gonna tell him all this. I'll log in tmrw and keep u guys updated.
