wheel fitment? please help!!!
usafdad120108
ok ao i want to get a set of rota slipstreem wheels 16x7 with +0 offset because i like the drift/drag rim look now my questuon is will they fit a 2000 civic ex? if not what is the lowest offset i can go without rolling my fenders etc. i just want the deep lip on the rim like the pic below open to suggestions thanks
lowlife9
the rims in that picture are either 15 or 16×8 0 offset so 16×7 0offset should work with stretched tires and negative camber.
Genuine Rolla
Its PETEY PETE, y0!
You'd need a lot of work to be able to ride +0 of an offset.
I'm not sure if they make slipstreams in a +0. Just go with some 16x8's +20 and you'll be good to go. You'll need to roll your fenders for them to fit ok
usafdad120108
it doesnt need to be +0 offset i just like the deep lip the rims have, I dont really want to roll my fenders what about like a 16x7.5 ??? I really dont want a bad camber either cause its my daily driver and i dont want to go through tires like crazy any advice anyone??
Ron...
You'll probably need to roll your fenders no matter what, unless your fine with quite a bit of neg. camber. I've got 15x6.5 +34 rims on 195/50-15 tires on my ek right now with very little camber. I needed to roll my fenders and I still rub around full-lock.
usafdad120108
ok here is what i want my civic to look like. in this pick this guy has 16x8 +20 offset. I like the wide tires and how flush they are with the fenders. Now to run wheels like these is a really neg camber needed or fenders have to be rolled? I just dont want to eat through tires like constantly
usafdad120108
well after doing some research and using one of the stickies lol I found a tire size calc that tells if it will fit or not so im going to get a 16x8 with 45 offset and a 205/45 tire says its only 10mm closer to fender than oem so it should fit perfectly thanks for your input guys
Genuine Rolla
Its PETEY PETE, y0!
But it's not going to have a deep lip like you wanted, which is why you started this thread, correct?
you can go to +40 off set and you'll be fine. +45 is pretty high of an offset and the wheels will look sunk in and not close to the fenders at all.
