when doing a valve clearance job...
2slo4u
wait4me
Camshaft bearing cap bolts
B18B1, B20B4, B20Z2.……………………………...................86 in-lbs
Camshaft holder bolts
B16A2, B18C1, B18C5
6mm bolts………………………………................................. 86 in-lbs
8mm bolts………………………………................................. 20 ft-lbs
Camshaft sprocket bolts
B18B1, B20B4, B20Z2.……………………………..................27 ft-lbs
B16A2, B18C1, B18C5.…………………………….................41 ft-lbs
Crankshaft fluctuation sensor bolts……………………………….........96 in-lbs
Main bearing cap bolts
Step 1
B16A2, B20B4, B20Z2.……………………………...............18 ft-lbs
B18B1, B18C1, B18C5.……………………………..............22 ft-lbs
Step 2
B16A2, B18B1, B20B4, B20Z2……………………...............56 ft-lbs
B18C1, B18C5
No. 1 and 5 caps………………………………....................56 in-lbs
No. 2.3. And 4 caps………………………………...............49 in-lbs
Connecting rod bearing cap nuts
Step 1
B16A2, B18B1, B18C1, B20B4, B20Z2.……………………14
ft-lbsB16A2.……………………………................................. ......30 ft-lbs
B18B1, B20B4, B20Z2.…………………………….............23 ft-lbs
B18C1.……………………………................................. ......33 ft-lbs
Crankshaft pulley bolt………………………………............................130 ft-lbs
Cylinder head bolts
Step 1.……………………………..................................... .......22 ft-lbs
Step 2
B16A2.……………………………................................. .......61 ft-lbs
B18B1, B18C1, B18C5
1995 and earlier………………………………...................61 ft-lbs
1996 and earlier………………………………...................63 ft-lbs
B20B4, B20Z2.……………………………...........................63 ft-lbs
Driveplate-to-crankshaft bolts………………………………................54 ft-lbs
Intake manifold bolts/nuts………………………………......................17 ft-lbs
Intake manifold air chamber nuts (B18C1)……………………………17 ft-lbs
Exhaust manifold-to cylinder head nuts……………………………….23 ft-lbs
Exhaust pipe-to-manifold nut……………………………….................40 ft-lbs
Exhaust manifold upper cover bolts……………………………….........17 ft-lbs
Flywheel-to-crankshaft bolts………………………………....................76 ft-lbs
O2 sensor………………………………................................ ..................33 ft-lbs
Oil jet bolts………………………………................................. ..............144 in-lbs
Oil pressure switch………………………………................................ ...156 in-lbs
Oil pan baffle plate bolts
B16A2, B18B1, B18C1.……………………………..................96 in-lbs
B18C5, B20B4, B20Z2.……………………………..................86 in-lbs
Oil pan drain plug……………………………….................................. ..33 ft-lbs
Oil pan-to-engine bolts………………………………............................104 in-lbs
Oil pump pick-up tube to pump housing nuts
B16A2, B18B1, B18C1.…………………………….................96 in-lbs
B18C5, B20B4, B20Z2.…………………………….................86 in-lbs
Oil pump screen-to-main bearing cap
Oil pump-to-housing bolts
6mm bolts
B16A2, B18B1, B18C1.……………………………..............96 in-lbs
B18C5, B20B4, B20Z2.……………………………...............86 in-lbs
8mm bolts………………………………................................. ...17 ft-lbs
Oil pump cover-to-housing
1995 and earlier
B18B1, B18C1.……………………………............................48 in-lbs
1996 and later
B16A2, B18B1, B18C1, B18C5.…………………………….60 in-lbs
B20B4, B20Z2.……………………………............................48 in-lbs
Oil pump relief valve plug……………………………….......................29 ft-lbs
Rear main oil seal housing bolts
B16A2, B18B1, B18C1, B18C5.……………………………....96 in-lbs
B20B4, B20Z2.……………………………...............................86 in-lbs
Timing belt cover bolts………………………………............................86 in-lbs
Timing belt tensioner bolt………………………………........................40 ft-lbs
Valve cover nuts……………………………….................................. .....86 in-lbs
VTEC lock-up solenoid bolts………………………………...................104 in-lbs
Water pump bolts………………………………................................. ....104 in-lbs
