when should bov go off?
2slo4u
wait4me
does the bov onlie come on when boost is reached? cuz before i was actuallie showing boost on the boost gauge..i would hear the bov and i would hear spooling..but now that im using the td05 turbo instead of the td04..i onlie hear the bov when boost is reached..and the bov is not making a woosh or w/e sound..instead i think it makes a little pssh then *cricket cricket cricket* it reallie does sound like crickets =)
ryanM
bov engages when you let off the gas, it sounds to me like you are hearing the wastegate. the wastegate should open while you are spooilng but only after you reach the amount of boost allowed by your wastegate spring. IE you have a 7psi spring in your wastegate, you will spool up to 7 psi and any boost beyond that point is expelled through the waste gate.; someone please correct me if i am wrong.
GreenSpeed503
Building A Screamer
its should go off when you shift and when boost is made, the point of a bov is to let the pressure out of the intake pipe as you let off the gas to shift.
Steven.
Formally Green 91
Sleeper said:
no load = no boost = no blow off
kinda wrong, we turboed a miata, every time you let off the gas it went off even a little, even if you never went near boost.
Matt.
if you honestly hear boost when your boosting, chances are you bov is too loose, tighten the valve up.
BuiltforSin
you can hear the bov in my friends eclipse even when he shifts around 1800-2000rpm. not very noticable but stil audible
2slo4u
wait4me
mine alwaise sounds like a little whistle..not even that noticeable..iunno wassup with it..im tak'n it to INTECRACING tomorow
