where can i find a turbo downpipe
civicracing98
im a cc whore :/
well im all ready to put my turbo kit on im just lacking one part, a 3bolt downpipe that will fit on my car (98 ex). anyone know where i can find a downpipe?? thanks
civicracing98
im a cc whore :/
its a t25 turbo btw
anfrey
OG スバリスト
your local exhaust shop. just fit-mount everything and have them bend u the downpipe.
j_fukin_t
www.kteller.com , they should have something for you and its all manderal bent
bizoneoeh
Ex-Gang Member
Yeah, just go to a local muffler shop. That's where I had mine made
civicracing98
im a cc whore :/
but im going to be running a 3 inch exhaust. everything i found for civics is 2.5 . could i jus get a nissan downpipe thats 3inches??
deaconwagers
...now rockin an integra
it would bolt to the turbo, but it wouldn't run under the engine & connect to your exhaust. buy a turbo outlet flange and go to a muffler shop and have them bend you one. if you insist on having a mandrel bent one, buy the necessary mandrel mends and a flange, and have a muffler shop weld it up.
civicracing98
im a cc whore :/
i kno all i need is a 3'' 3 bolt flange then all i would have to do is get a downpipe bent. anyone kno where i can find one and how many would i need?
civicracing98
im a cc whore :/
so if i got a sr20 downpipe with a 3'' 3 bolt it wouldnt run under the motor??
deaconwagers
no. the sr20det is a rwd motor. the exhaust (and turbo) are on the drivers side in a 240. the downpipe points straight back and drops to clear the firewall. on a fwd car, the downpipe faces either right or left, then point straight down, then wraps under the oil pan, pointing a different direction than when it exited the turbo. an sr20 turbo OUTLET would bolt to the turbo, but you would still need the rest of the downpipe.
deaconwagers
***correction***
it might, if it were designed for a fwd car. however, in all likelihood it would not be anywhere close to your factory exhaust.
any way you cut it, the fit and the price will be better having it made custom at an exhaust shop.
io_303
NIFOC
they can make others, shoot thme an email, my friend got one for his TDO5h using an HF and an adapter plate
anfrey
OG スバリスト
dude, put the flange off and have your local muffler shop fab the downpipe for you. it's the easiest, least time consuming, and possibly most economical solution. i'd rather do this than attempt to scour for parts that aren't even for our cars.
civicracing98
im a cc whore :/
look at the prices for downpipes. id use them to make a downpipe but i cant see 250 dollars in a piece of mandrel bent piping.
civicracing98
im a cc whore :/
so anf my best bet is getin a downpipe made?? i think finding a flange or even having one made from the downpipe elbow is gonna be a pain in the ass..
io_303
NIFOC
its worth it, its 3" mandrel bent to the stock exhaust location. Its good quality work.
anfrey
OG スバリスト
it's the least troublesome, imho. granted there are 4 or 5 exhaust shops in my neighborhood alone, i know any of them could have a pipe bent and welded in a matter of minutes.
i do suggest you shop around and ask what bending machine their shop uses. mandrel benders are obviously something to look for. if it gets too pricey or you can't find a shop with a mandrel bending machine, you could settle for a ben pearson style bender, which isn't as good, but still beats out crush bends.
Going-West
Tree people on my radio
i have the opposite situation, im getting a 3'' downpipe and i have a 2.5'' exhaust...i can't find a flange anywhere :( can anyone help?
as for your question, an exhaust shop can make on for you, and the link posted above is good. lots of companies male 3'' downpipes, if you don't want to have a shop make you one, do a google search for 3'' downpipe and you get will a lot, i was just searching for flanges and i found a lot of 3'' ones..
