Alright, and do I just do another of the hex bolts for the oil press. gauge? sorry if that's a dumb question, cause i haven't even looked at the instructions for it yet, I'll do it in just a bit, ha.you can either add a brass T from the oil sensor in the back or have it come off an oil sandwich adapter.
to use the brass T, you'll need a deep socket 24mm i believe to take off the sensor..apply teflon tape where needed..
to use the sandwich adapter just take off the oil filter and turn the adapter on to where the filter once was..make sure its tight..then reinstall the filter..the adapter will have little holes that are blocked by hex bolts, just unbolt and put the oil feed line fitting in
