power port? what is that exactly?96greencivic said:You could tap into the power port and then it would only power when the key is in the car.
Sorry, I couldn't think of the right term. The power plug where the cig lighter would be. Take off the panel and tap into it's power line.celwin said:power port? what is that exactly?
How would that be the easiest? He has to pull the deck to plug in the data cable behind the stereo. Three t-taps (power ground and accessory) and hes done. Run it to the tuner, clean it up with zip ties and hide the whole thing in split loom. I wouldnt run any more wire under the drivers side dash. They always fall out and look like crap in the long runhandlebarsfsr said:or do the easiest, there are several acc plugs in the fuse box under the drivers side dash. a few standard female plugs and a light will tell you which is switched and which is constant. plug them in, and your done. no cutting, splicing, soldering required.
