how can you possibly recommend any injector without knowing what turbo he is running? 12-18psi on a t25 wouldnt even come close to maxing out DSMs, neither would 12-18psi on a t3, 14b, blah blah blah12-18 psi..i'd recommend 550cc and above.
possibly.would the serial numbers be able to tell me what kind of turbo it is?
Dude with that build you could run 400hp DD with a good tune NP. Sleeved FTW. I'm actually going to be running a manual dual stage boost controller low setting shooting for 370hp high setting about 470hp. Go with an OEM Honda Headgasket.thanks neo, you're the nuts...as far as a hp goal, i honestly have no idea. i guess whatever the engine will do. apparently, my motor is going to be more of a beast than i thought. my shop said the head alone is built for around 500hp. i think 500 hp on a dd is a little much. originally i was hoping to be around 300. so far my setup has:
bdl cam gears
crower 402T cams
crower valves/springs/retainers
wiseco pistons (9.0:1)
eagle rods
arp rod bolts
all new bearings and thrust washers (race spec)
sleeved/bored/honed block
skunk2 intake manifold
turbonetics turbo/wastegate (7psi spring)
hks ssq bov
2.5" intercooler piping
spearco intercooler
and probably some other s**t that i'm forgetting. i guess my biggest question is when is it enough. and what thickness head gasket should i get? i didn't know they came in different thicknesses.....i always thought a head gasket was a head gasket.
