which kind of engine is better to turbo
itsmycookie
#1 a*****e
consider two similar engines
simple question, which engine would better to turbo?
A SOHC or a DOHC
knifeman
down-under boy
well a dohc and a sohc aren't similar......however as for all applications it depends how fr u want to take it.....imo dohc would be
Tom
honda.co.jp
no doubt in my opinion it's the dohc, no matter what you'll always be able to get more power outta a dohc then a sohc.
civic95
it is sort of about how much money you have and want to spend on this. Your car obviously already has a SOHC in it, so you'll just have to turbo the engine that's already there, in which case you can either spend the money on a kit or create a custom kit. Either way lets say you boost at like 7psi and already at ~170hp
For a DOHC, you'll have to spend the money buying the swap, which is probably going to cost more than the turbo for the SOHC in itself, and then you'll have to turbo the new engine. But you'll be making more power at 7psi than the SOHC. Also the internals on a DOHC are stronger and can take more abuse than the internals on a SOHC. There are a lot of variables so you gotta narrow it down and see what u wanna get out of the engine and what your cash status is.
itsmycookie
#1 a*****e
no this is not about my car
just about which head handles a turbo better
Handlebars
None Taken.
in general- both can do the exact same thing. the build of the motor itself is far more important than how many cams it has- although dohc h as a slight advantage as to allow shorter or no rocker arms than a sohc. thats about it.
SeanMc300
professional a*****e
what kinda motor is best? a working one. the one that will handle it better is the one that is built for it....or in my case, the one i got =)
