egsidev
Set up
1993 Si hatchback
Super tech valvesprings & retainers
81mm CP Pistons
Eagle H beam rods
ACL Bearings
1000cc iD injectors
iD Fuel pump
Stage 3 Comp clutch
LS Crankshaft
Skunk2 Pro series ported 70mm intake manifold
BWR 70mm Throttlebody
Hondatas300 v3 boost by gear
3 inch exhaust
Moroso tapped oil pan
New everything else (oil pump. water pump. thermal gaskets. etc)
Question, what is a good turbocharger to grab? Just want to hear opinions on a turbo that's capable of holding and putting out this power. This is mainly a street car, but will be at the track occasionally. Hoping to get around to 500hp. Thank you.
1993 Si hatchback
81mm CP Pistons
Eagle H beam rods
ACL Bearings
1000cc iD injectors
iD Fuel pump
Stage 3 Comp clutch
LS Crankshaft
3 inch exhaust
