Will sedan parts fits to my EJ6 coupe?
march
Parts I want to change are: windscreen wiper motor, front fender and those trunk rods
CO671
What year sedan and what year coupe?
-Wiper motors confirmed can be interchanged
-Fenders
depends on the year. Only 96-98 are interchangeable within those years, and the same goes for 99-00.
-Trunk rods (only hinges can be used, springs can't be)
Hinges can be used from any of these vehicles:
Springs/Rods must be from the year it's meant for
edit: I made this thread a while back. If you want to know the interchangeability of OEM parts use this:
http://honda-tech.com/showthread.php?t=3092357
--Decided to make this thread after posting a write-up in another thread regarding interchangeability. If anybody has better title ideas that are catching/effective , please let me know!
Here's a trick I've used to see if parts are interchangeable, it may not be 100% accurate because you never know until you try and modify a part yourself.
The first set of instructions are for OEM parts that are interchangeable between USDM Honda vehicles. The second set of instructions below are for aftermarket brand name parts that are interchangeable among Honda vehicles and other makes & models, if listed.
Here's the situation for example:
I'm low on cash, I can't afford to get that replacement radiator from the auto parts store, can I just pick and pull a part from another vehicle and use it in mine?
Here's how to see which OEM parts are used in other vehicles.
  1. The best site I found this first method for is www.HondaPartsNow.com
  2. Choose the model, year, trim, and transmission of the vehicle you're trying to source parts for. ex: Civic > 1999 > 4DR DX > KA5MT
  3. Navigate to the part you're in search for. ex: radiator and find the part # for it, here in this picture it's #1 "19010-P03-505"
  4. Copy the part # and use the search box at the top of the webpage
  5. Now the website will list other vehicles down to the year, trim and transmission that have that same part #.
  6. Go out, spend wisely and make sure the part you need is in good condition.
Here's how to see which aftermarket brand name parts are used in other vehicles, sometimes different makes too.
I need a new a/c idler pulley, what other vehicles have one that can fit mine?
  1. I use RockAuto.com for this method, and it only works with the updated part catalog style.
  2. Navigate to the vehicle. ex; Honda > 1999 > Civic > 1.6L L4 SOHC .
  3. I need to purchase a new A/C Idler Pulley. Belt Drive > Idler Pulley
  4. Click on the part # link (if available) and a pop-up will display other vehicles that have the similar part. Click on different brands/parts links, because different manufactures may list different vehicles interchangeability
  5. Grab that part and repair the problem!
march
Sedan year is 1997 and my coupe is 1998. So I need to buy rods with hinges. I am very grateful CO671!
CO671
Yesssssir! Just get a proper coupe set
march
Does Civic Type-r Ep3 streering wheel fits perfectly to my civic ?
I have Civic Coupe 1998.
