window help
Rmusgr
Hello,
I have a 1996 Civic. power window on drivers side work fine for a while then comes off track when putting it up. i took door panel off and put it back on track it worked fine then it came off again. the rubbers in the tracks are fine. i greased everything up. does any one have any suggestions?
Thank Rick
RMusgr@hotmail.com
rey rey
"the rubbers in the tracks are fine". I had the same problem and to replace the rubbers because they had a slice right down the center where you could not see. the guy at the shop said that was a common problem with honda 96-98.
Rmusgr
Thanks for thr reply
That may be possible! it seems when it comes off track it jams
forwords towards the front track
rey rey
Mine did the exact same thing. And when they took it apart it was the back track that was messed up. So the glass would lean forward come of track. Good luck with that let me know what happens.:thumbs up
Rmusgr
I will check it out tonite, now i have some place to start looking
Thanks
aPok RaceR
bLunTed
i know this is an old p0st, but just wondering how much did it cost to replace that rubber piece? +labor? thanks
lanojp1
my window recently started doing that, it would sound like a shotgun when it reached the top of going up, i took it in and they had to replace some piece, im not help cuz i dont remember what it was called but it was lke 45 bucks...
