Window, moonroof, taillights, doorlock, HELP PLEASE.
wtfh4xx
1337 Gold Member
I dont want to pay 140$ to diagnose s**t so here goes:
Passenger side window: Ok, I can roll it up and down fine and it seems ot still eb on the track. However, once it gets up to the seal it will make a noise and just sit there goin up and falling a half in then going up and fallign down a half inch. Any ideas on whats wrong? How do i fix?
Driver side doorlock: FIXED
Driver side outer taillight: Sometimes comes on, other times it wont. But the very same light is also a brakelight and it works when I hit the brakes...
Moonroof: FIXED.
Sundown
The Driverside tail might be a short somewhere.. check all the connections and grounds..
The moonroof sounds like its done.. does it not roll backwards at all? That doesnt sound good. I dunno much about the sunroof in civics, but do they have seperate motors to lift it up and push it back? if so, the one to push it back might be out..
Driver side lock problem is one that ive seen before, but I really couldnt figure it out myself..
For the window, is it in there straight? it sounds like it could be in there crooked or something :what:..
wtfh4xx
1337 Gold Member
Window is in straight. I have half the damn door off now and I cant figure out whats wrong.
IM going to go look at the driver side and fix the lock.
As for the moonroof i think the buttons stuck or broken.
Button is below. It is a two peice. Center botton is in middle and raises moonroof. Top shuts the moonroof. Bottom should slide it back. But the bottom is stuck i think.
___
Taillights seem to eb workign after this morning battery Disc. I did.
wtfh4xx
1337 Gold Member
moonroof: Fixed.
Doorlock: Fixed.
Still need help on:
Driver side lock
Passenger side window.
BTW: I gues the door is SUPPOSED to do that. lol.
wtfh4xx
1337 Gold Member
Window: SOLVED
Gear is stripped at the top end. Getting new one from junkyard.
