so my window fell off track for the 5th time today. keeps falling off track, everytime i take the door apart, spray some silicone lube in the window track and it works fine for a day or two. this is really pissing me off now, any suggestions?
damn that sucks ive had that problem before and it fell in. i jus took it to the dealer and they took care of it works fine now but. its kinda slow going down now esp when its moist sucks i think its the relays.
what i do is never have the window go lower than halfway down. It always falls of the track on mine if i let it go any lower. Some people have suggested adding a washer to the lower bolt behind the speaker.
better is to find a longer bolt and add a nut to the back, to more you tighten that track due to it not getting "tight enough" you are stretching the threads. Or call you local honda dealer, check majestic, or HOP for OEM tracks. STAY AWAY FROM EGAY
So I tried adding washers I treied longer bolts and I tried just leaving the bolt out. All result in my window constantly falling off track. Iwant to be able to put it down and up grr. If I bought a new track how the hell so you install them? The space ia so tight and u can't see the upper bolt...
