any ideas how to remove window tint on a rear window with defrosters u can use a razer blade.
4doorcivic16 New Member Registered VIP 5+ Year Member 10+ Year Member Apr 16, 2008 #1 any ideas how to remove window tint on a rear window with defrosters u can use a razer blade.
Jimmy2times White, middle-class Registered VIP 5+ Year Member Apr 16, 2008 #2 i wouldn't. u could cut the metal ribbons.
wetcmonkey New Member Registered VIP 5+ Year Member Apr 16, 2008 #3 hmm goo gone? or a heat gun to prevent ripping the defrost lines...and then use the goo gone to clean up the adhesives.
4doorcivic16 New Member Registered VIP 5+ Year Member 10+ Year Member Apr 17, 2008 #4 i mean u cant use razer blades thats why i ask i havent tryed goo gone i tryed the heat gun but it didnt do anything.
Jimmy2times White, middle-class Registered VIP 5+ Year Member Apr 17, 2008 #5 hmmm. idk about the heat gun. if u get too close, it may melt the tint to your windows. u could get it professionally removed. idk how they do it tho.
TiiM iiS l3eAsT Scamming Piece Of s**t Registered VIP Registered OG 5+ Year Member Apr 18, 2008 #6 my buddy took his off with gasoline....seems to worked...ive never tried it though
el_betiyo New Member Registered VIP 5+ Year Member Apr 18, 2008 #7 do it on a hot day and some gasoline will do the job, just be careful with the defrost lines
MajEK Cry Some More Registered VIP 5+ Year Member 10+ Year Member Apr 19, 2008 #8 Good-lord search! Just use some ammonia. Let it soak and peel it off.
honda98civic New Member Registered VIP 5+ Year Member Apr 20, 2008 #9 walmart sells this stuff called tint remover. i would try that hence the name lol
preMier_ciVic New Member 5+ Year Member Apr 22, 2008 #10 http://www.tintdude.com/remove.html that will do it
johno590 f**k thieves Registered VIP 5+ Year Member 10+ Year Member Apr 22, 2008 #11 Yeah follow the directions with what that link says, don't listen to everyone else... sweating it out works and usually wont mess up the defrost lines
Jimmy2times White, middle-class Registered VIP 5+ Year Member Apr 22, 2008 #12 interesting. i'd like to see that process done. sounds like u need to work quickly.
Schenck New Member 5+ Year Member Apr 23, 2008 #13 U don't need to work that quickly, u just gotta know how to do it. But if u got the money u could always take it somewhere but I wouldn't do that. Y are you taking the tint off ur back window?
Flip8Speed New Member Registered VIP 5+ Year Member Apr 23, 2008 #14 if you got full coverage just bust the window...naw jus playin'. my buddy does tints ill ask him.
