Well if the window is off the track it will still move, it just looks like it will fall out when you roll it up. to take off the door panel at least on my 97 you take out the plastic pieces arounf the door handle, and where the window remote is, disconnect the wires, the pop off the speaker cover, un bolt the speaker, unplug it, then there are three holes there, take thoese screws out, then along the inside of the door panel alont the bottom there are clips the hold the panel on, you are suppose to use a speacial tool so you dont break these, but you can use what ever you want, you prolly will brake a couple but thats okay. after that the door panel will just come off lift up then out. This will give you access to the door lock mechanisim, and window motor and so on! good luck, sorry if you already fixed this I dont like to look at post dates
