+ wire near fuse box? (99' civic EX)
BEAR_times
Undeniable
My pf mirror project is almost finished. The + wire on the relay linked to the + of the switch does not give my relay power. I linked my relay + wire directly to the + battery terminal and my mirrors fold in and out. I need help finding a good + source near the driver side under dash fuse box(preferably). This may be a little difficult because there are over 100 different wires. Thanks
radracer
have you tried to connect it into the slots on the fuse box above the fuses where you would connect the power wires for fog light harness one of them is positve all the time and also key switched , i just forgot which one it was , too cold and snowy to go out n look .
but if u got a test light im sure u can figure out which one it is
BEAR_times
Undeniable
I tried using a fuse tap with the radio clock slot with no luck. I also tried the heater A/C relay and it didn't give any juice. What should I do next. It seems like my best bet will be to tap into a + wire. Anyone have a suggestion? This is the last step I need for this project. Thx
radracer
look just above the fuses , on the fuse panel there will be a few small square openings with a male spade terminal in it , those are your + wire hook ups . some of them are B+ which are constant, theres one thats powered when the key is on and one when the lights are on . just dont remember which one was wich , but like i said in a previous post if u have a test light you will be able to figure it out ,
hope this pic is of some help
