wire to battery
iibtc
how do you connect a wire to a battery. I have an inline fuse and that stuff but what else do i need? Anyhelp appreciated.
civic99coupe
just get a ring terminal and solder and crimp it onto the wire...connect the ring terminal to your battery's positve end...the other end of the wire ..put it into one end of the inline fuse...then take another wire and put it to the other end of the inline fuse and then run this wire to i assume your amp.
make sure to disconnect the negative side of your battery whenever doing electrical work. =) hope tihs helped
