Does anyone have a diagram or some info about the wiring from the clock (dash)? It's for an EG6. A friend of mine doesn't really know which wire is what. Need to know as soon as possible. Thanks in advance!
it should be prewired. pop off the hazards switch, remove screw behind switch. then pop off the bezel and you will see a wire harness on the back of the clock blank piece. take out the blank, put clock in, plug in and you are done.
*edit: just follow the first couple steps in the link to get the bezel off and access the clock harness:
