donkeylips87
After finishing my Mini Me I am having some issues. I also did the following:
97 Civic D16Y8 Mini Me.
Pistons and Rings with P2P
Timing Belt
All Acc. Belts
Rear Main Seal
Rod Bearings
Main Bearings
Head Gasket 2 Layer
Brand New Knock Sensor
AEM Tru Time Cam Gear
Fresh Hone for Cross Hatching.
ARP Head Studs
Clutch and Flywheel
All New Coolant Hoses
New Air Filter
P2P ECU OBDII
I have been working on this for a while now. It is not my DD. It used to be my wife's and she would like to drive it again some day. All symptoms sound like timing to me. If I use a timing light and time it, it back fires when it's rev'd. This happens no matter what my mechanical timing is. I currently have it timed at 6 degrees advanced in mechanical timing to make it drivable. If I give it throttle while cruising, it shutters when I press the pedal down and then again when I let it out. It also seems more sluggish then before the swap. Also, when I start the engine and it is cold it will idle for about 15 secs and then start to die. Then the rpms pick up just fine for a couple seconds. This will happen 3 or 4 times before it goes to a normal idle and stays there. It misses sporadically at idle. The block is a Y7. I am using Y7 injectors, Y8 I/M, and Y8 Dizzy. I am lost from here. I'd really like to get this running. Any help would be greatly appreciated. Thanks.
Timing Belt
All Acc. Belts
Rear Main Seal
Rod Bearings
Main Bearings
Head Gasket 2 Layer
ARP Head Studs
Clutch and Flywheel
New Air Filter
P2P ECU OBDII
