Z6 onto y8 block pros n cons help
earlybill1
First off what is a z6 dizzy I keep reading but have no idea what that means? Ok now Im driving a 97 Civic ex with of course a d16y8 now what are the pros and cons of swapping the head to a z6? Can it give it more power or less. Why do tuners do this is the z6 a vtec? Just any info I can get will or mite help me understand a bit better. I really wanna Turbo my y8 but the shop I've been talking to in Alabama (Trackmasters) says it would be cheaper and better to just swap to a b16a because I'd have to have my y8 bottom end built and that would cost as much as the Turbo so it would be $3500-$4000 for b16 and $6000 plus for y8 built plus Turbo guess I'd go with b16 what would y'all do thanks for the advice
Droidx,97CIVIC
lethal6
Your Mom's Moderator
Z6 dizzy = distributor for the z6 head.
What would I do? Swap to b-series then boost.
mc360
boosted hx
You don't need to build the bottom end unless your going for over 220hp which is the max safe limit for the stock rods and pistons. I have a d16y5 turbo that's all stock making 166hp and 149tq which is better than a b16
Failsafe88
gt CasaNova
look leave the head on there cheapest route is to get some vitara pistons and some new rods scat or eagle. Get stock bore 75.5mm that way all that will need to be done is to get block notched for pistons. Can leave the head alone. Then after that get you a small little turbo setup nothing special. Do not cheap out on the turbo though aka ebay. Can get a used turbo or buy a rebuilt one for 500 and under. I would get a simple little t3t4 or even a gt28 turbo if you can afford one. Then get the rest of your tubo essentials i guarantee that if you turbo the d series even stock and get a good reliable tune it will beat the b16 without a doubt.
CIVIC_VTEC
LOW AND SLOW!
save more money getting low comp pistons and ebay turbo the y8. Their very strong single jingles with turbo.
