Yes and my 96 SiR came with ABS which also you don't have in USDM but we do not have the cruise control^^ you have leather on the exterior of your civic?
fukin usdm
ABS was an option for the other trims, but not Si. cruise control is standard on HX, EX, Si i believe (usdm) and an option on the others. i want to see a pic of this exterior leather tho!!Yes and my 96 SiR came with ABS which also you don't have in USDM but we do not have the cruise control
yeah i got that window problem in my rear right passenger side, always gotta hold the window in a way so u can actually bring it down, it shifts side to side like crazy.....especially in the winter^^ .
Yeah our little economy car's aren't exactly a comfy and quiet SUV or BMW. But your window really could be sitting at an angle. When you shut your window, hop outside and take a look around the edges where the rubber meets the window. Make sure you can't see the edges of the glass or that any rubber is disfigured and letting air creep in. If you do see that the glass isn't sitting properly, you most likely have a bent regulator (it's what the bottom of the glass sits on as it's pushed up) or your track could be bent too possibly...?
I know for a fact my regulator in my driver side is bent so it causes the upper left corner of the glass to not fully seal against the rubber. I can literally put something between the edge of the glass and the rubber. That's how far off it sits. So I have to push on my glass to the left as I roll it up and it seals properly and I don't hear the wind noise anymore.
yeah i seriously gotta see this tooABS was an option for the other trims, but not Si. cruise control is standard on HX, EX, Si i believe (usdm) and an option on the others. i want to see a pic of this exterior leather tho!!
He's from another country. I'm thinking he might mean "rubber" or something though.I had the same problem with my previous car 98 LXi and after a lot of testing i found out that noise was coming from the exterior leather protection of window frame ...as the car gets older the leather loses its flexability and become hard and slightly leaves a gap between the glass and we you reach 60 mph or 100 km/h you start hearing the noise.
My 96 Ex has ABS MT and cruise controlYes and my 96 SiR came with ABS which also you don't have in USDM but we do not have the cruise control
Exactly...sorry for the inconvenience ...i meant rubber ...He's from another country. I'm thinking he might mean "rubber" or something though.
Leather is the material that comes from the hide of cows. Some of the things that are made of leather are jackets, furniture and car seats.
Right, but the USDM Si (EM1) does not have ABS even as an option. The Canadian ones have it though.My 96 Ex has ABS MT and cruise control
