i cant think of the name besides polishing wheels. its a pretty strong drill bit with a metal scrubber on the end. works like a charm and doesn't scratch the surface. just did my valve cover and it was crazy dirty
Yep. Emery cloth ftw...
emery cloth and i also use those green scrubby things for the tough spots to start
Yep, about a gazillion times. If you have an air compressor the green nylon/plastic wheel brushes are good too.
I feel like I keep repeating myself lol. Just go at it and don't be scared.
Well I ended up not getting emery cloth today. I had soft plastic brush polishing bit for my dremel which worked like a charm. I just ate through the whole bit. I'm hopefully going to get another bit tomorrow and I'll post some pics soon.i cant think of the name besides polishing wheels. its a pretty strong drill bit with a metal scrubber on the end. works like a charm and doesn't scratch the surface. just did my valve cover and it was crazy dirty
Yeah, I thought about that, but I didn't have the time to cut a hole in the front for it to come out. I will probably do that later though.Tuck looks good. I ran my wires under the metal piece for some extra security. Spill your guts on this fab work
No, it was a stretch, but I was able to connect them without extending them. The two wires running the whole way back are for the sidemarkers.
The only wires I cut and re-soldered were for the wiper motor and the two going to the master cylinder. I just did that so it would be easier to run them under the windshield wiper cowling. I'm not sure if they would have to be extended for other chasis/trims. Looking at the passenger side though, I think I'm going to have to extend those wires to make the connectors meet. If I do, I can take some pics and make a how-to.I'm guessing in some cases you do have to extend them don't you???...
Sure thing man. Are you tucking your bay as well?Thanks that would be great...
agreedTuck looks good. I ran my wires under the metal piece for some extra security. Spill your guts on this fab work
no, but on passenger side you will need to extendI'm guessing in some cases you do have to extend them don't you???...
i recommend just cutting out the brake fluid level wires, and also the wiper motor wires you could have just pryed the oval opening some and wiggled it through. it woked for me.The only wires I cut and re-soldered were for the wiper motor and the two going to the master cylinder. I just did that so it would be easier to run them under the windshield wiper cowling. I'm not sure if they would have to be extended for other chasis/trims. Looking at the passenger side though, I think I'm going to have to extend those wires to make the connectors meet. If I do, I can take some pics and make a how-to.
Haha yeah, I was going to post more on that later. It's actually an OEM one way check valve. It comes stock on all EGs and DCs. Their valve is not integrated into the line like the EK. I'll get some pics tomorrow.Well first off, do i see a home made brake booster hose with a one way valve you put in??? if so, where you find the valve?
but yes passenger side is a much harder ball game, driver side is a joke
ah ok, ill have to get myself one of those eventuallyHaha yeah, I was going to post more on that later. It's actually an OEM one way check valve. It comes stock on all EGs and DCs. Their valve is not integrated into the line like the EK. I'll get some pics tomorrow.
Yeah, I probably could have fit it through, at the time I was kinda in the mood for soldering haha.
I was looking today and I think I have to move the blower motor out of the way to even get access to the inside of the door grommet. Is this how you did it?
Alright cool. It looks like it'll be a tight squeeze though haha.ah ok, ill have to get myself one of those eventually
but nope, only time i had to loosen the blowe was for the fusebox harness but i didnt have to take it out. since i knew i was going to be extending i just cut the wires on the interior side, ran a feeder wire through, and pulled them up and out and soldered them back together
Alright cool, I'm about to get started.you will be fine, you an actually see teh door grommet light when you take the plug out and look up to it
Yeah, I think I know how you did you wiper wires. I was going to do it the same way, but I couldn't get it de-pinned so I said screw it and just cut the wires. As far as the passenger side goes, I can't see how you managed to not cut them, but I'll see what I can do.I didnt extend wires on either side (i suck at wiring so i made a point not to cut anything) and my wiper motor wires were the hardest to deal with, but i de-pinned them and fished them back through some holes and reconnected it under the cowl. Takes more time and patience, but it can all be done without cutting.
