yeah you will be fine with that setting on such a small turbo. Going into this you should know that the 14b, much like the t25, will die out at higher rpms...like 6grand. that turbo is more of a low--mid range turbo. its great for a daily driver who wants some passing power on the highway. you wont blow anything up. if you are set on using a fmu setup, you do NOT need those injectors, your factory ones are the ones you should use.
