Ok i checked those didnt do anything its only that way when its cold cause today the temp got up to 70 for some reason and it started so much easier but still had a lil trouble and it backfires when it first gets started if you peg it to the floor so im thinking mayb its not getting gas good enough or the fuel pump is bad. need help quick projects almost done only gotta put the bumper on and rims.make sure you didnt reverse your tps and map sensor plugs, the plugs look identical and its a common problem, check that and let us know!
