I think you need to read more with that budget you have.I just bought a 92' Civic CX, I am looking for an engine that will bolt right up to the car without changing anything, it has a D15B8 in it right now.....tiny engine, what engine bolts directly to the mounts and is good enough to hold boost maybe 10-15lbs? any help is appreciated
I have been looking on JDM sites for a new engine, any other suggestions?
It's the internet, the info is out there, you'll want to read up and understand what and how to do it.Do I have to do anything special to get the Z6 head bolted on?
If you can, I would get the Z6 intake manifold, it a bit different, the d15b7/b8 are a bit more restrictive than the z6. It will give a little bit better performance, especially mated to the matching head.Also if I do change those two things should i get the d15b8 manifold/TB or the z6 manifold/TB?
The used market obviously, Craigslist, local salvage yards, classifieds on Honda forums.wheres a good place other than ebay to shop for car parts?
How is it lacking? It looks pretty self explanatory.am i gonna have to do any modifying/machining? Especially if i get the TB and Intake Mani? The info i have read so far is kinda lacking in description
Well it depends on what component is causing you to burn oil. Most common thing is going to be piston rings, and that should be included in a rebuild "kit". I would do some diagnostic work to find out why the engine could possibly be burning oil first. Compression test, power balance, leakdown.... etc. But there is a good place to start.I can rebuild my engine for the same cost as buying a new one, still no luck on finding a decent motor, the rebuild kit is gonna cost $390 and it comes with everything i need to do the work...but the current engine is burning oil, if i rebuild it would that fix the problem?
I'd also consider valve guides/seals have gone bad.
That's probably in the rebuild kit, right?
