JoeyStyyles
I recently bought a 94 Hatchback with a puzzling problem with the cluster. The temperature and gas gauges work fine but the speedometer idles at 30 Mph. I did a little research and found that the sensor that it runs off is normally connected to the transmission. Now I'm wondering if the problem is either in the cluster or in that sensor and how I would go about finding out which is the problem. I don't believe that the cluster is stock.
I'm also wondering if a cluster with a tachometer (from the same generation of course) would hook up without additional wiring, seeing how this one is lacking that.
Any help would be appreciated.
Thanks!
Thanks!
