Can you be more specific here^? What wire?So I found the wire going to the ecu from the harness and it seems I'm getting power out of ther but no power to harness.
You mean the Wht/Blu wire from the 7.5A hood Back Up fuse? If so, the fuse is probably blown. Check it.It was a white wire with blue I believe.
Click the phearable link I posted.Do you have a pic diagram of which on is A7 or A8? I'll try tomorrow when I have light.
This^ tells you that the main relay gets power from the hood fuse box and the ignition switch and that it works properly - no problem there.Ok so I ran the wire from a7 to ground and I got power at the fuel pump.
