I said it before I slammed the car I'm going to take a picture of the sway bar before I take it out its really low it sits like three to four inches lower then my oil panstill tryin to picture how you bottomed out the front sway bar lol
I'm trying broShine up that bay now and make it as perty as the outside :p !!!
still weird. The sway bar bolts on the lca and goes upward... and if you hit it on the ground it would be pushed higher up, and there are many things that naturally sit lower than the sway bar. Just sounds crazy strange, but strange things do happen.I said it before I slammed the car I'm going to take a picture of the sway bar before I take it out its really low it sits like three to four inches lower then my oil pan
Using the tapa ya tap tap..... Tap
this, that's what I couldn't picture bc the sway bar goes over both the exhaust and shift linkage. in for pics!!!still weird. The sway bar bolts on the lca and goes upward... and if you hit it on the ground it would be pushed higher up, and there are many things that naturally sit lower than the sway bar. Just sounds crazy strange, but strange things do happen.
Not if it is the suspension techniques front swaybar that bolts on to the cx and dx lca's. that bar goes under everything.this, that's what I couldn't picture bc the sway bar goes over both the exhaust and shift linkage. in for pics!!!
