:omg:
Because 19Y so many stickers?
Meh, its two magnets.Y so many stickers?
It drives perfectly straight. The color difference doesn't bother me much. I will eventually repaint it silver or another color, but for now it's fine. I just really love the 98-01 front. I'll get to pulling the bumper to find out the damage and see what's up. The rust I do need to deal with. Gotta find someone who can do it around, and then figure out those wheel well plug issues.Because 19
Does look pretty good for the price, better than the last one, mos definitely! And the sooner you take care of that rust, the less it'll cost. I also thought I could tell the color wasn't perfect front to back, but you can smash up a car pretty good and only do cosmetic damage. As long as it drives straight I wouldn't worry much. Doing a front end conversion could be problematic though, depending on the quality of work that was done to put it back together.
Yeah it's the wheel well plugs or the rust so when it stops pouring and I'm home, I'll check it. I didn't get a chance yet to pull the hatch interior apart so I'll check the defroster when I do and I got my wiper motor so I'll throw that in as well. Hopefully none of the defroster lines are ripped.integral are notorious for trunk leaks
what you coming to leesport for? that's basically where I live
and I already told you your emissions sticker issue. failed or from non emissions county so you need to go get it done
make sure they plugged the rear defrost back in and the taps aren't broken off that connect to the window
my ls doesnt really do that good. 30-32. him and i both have high mileage engines though and are not as tuned or efficient probablyRobs gsr with the ac on gets 32. His is heavily modded and tuned too. :-p
Sent from my Note 2
hmm never did lock from the passenger side on mineGot another question for you Kelly. The door locks, in my old car if I held the key on unlock or lock it would unlock or lock the passenger door as well. This one only works with unlock when you use the passenger side lock
Sent from my Nexus 7 using Tapatalk 2
The ONLY way (that I know of) that a "heavily modded" GSR is going to get that good of fuel economy, is if the basemap is tuned incredibly mild. My b20 Integra, which had a great basemap, and was tuned quite well, got 30mpg when I was driving it normally.Robs gsr with the ac on gets 32. His is heavily modded and tuned too. :-p
Sent from my Note 2
As far as I know, it only unlocks. He has never locked it that way. I'll try it before I leave for work since he's off today.Got another question for you Kelly. The door locks, in my old car if I held the key on unlock or lock it would unlock or lock the passenger door as well. This one only works with unlock when you use the passenger side lock
I honestly do not know how he has it tuned, but I know he's in the garage changing it every once in awhile. He's taking it to the track this week so I'm sure I'll lose him to the garage for awhile again.The ONLY way (that I know of) that a "heavily modded" GSR is going to get that good of fuel economy, is if the basemap is tuned incredibly mild. My b20 Integra, which had a great basemap, and was tuned quite well, got 30mpg when I was driving it normally.
As far as the damage, as long as the frame/radiator support, and impact beam are all straight and in-tact, who gives a s*** about the cosmetics? Most cars have been in mild fender-benders. If the bumper cover and impact beam had to be replaced, but everything else is fine, it's not a big deal. You really can't be nitpicking these cars, particularly considering the age of the car. They have been molested and driven into the ground like crazy.
hmm. Weird. If you took the key in my auto teg and put it in the driver door and turned to unlock and held it for a couple seconds, it would unlock the passenger door as well. Same thing as if you would hold it on lock. If you put the key in the passenger door and held it on unlock, it would open the driver door as well as lock. The door locks weren't changed as far as I know and looked normal when I had the door panels off so idk. The driver door does unlock from the passenger side though so it's weird.As far as I know, it only unlocks. He has never locked it that way. I'll try it before I leave for work since he's off today.
