97 Turbo HX
SickEk
here is the list for the motor build and what has been put in it. I didnt get on here sayin it had 300 at 10lbs of boost with my life. i said that was what it was dynoed at by the previous guy not me.
Here is what I was told about the car. Any question just ask me.
This car is easily a low 12 to high 11 second car that was built for daily driving. It weighs 2100 w/o driver and makes over 350 HP on 93 octane fuel. Other than the front bumper needing painted, the car is in excellent condition inside and out. The entire car has been gone over and is in excellent mechanical condition and is very, very reliable. Even with 350+ HP, 35 MPG is easily acheived. The car runs very good and drives like stock. I have countless hours of tuning in the car to make the car drive flawlessly in all conditions. Since the new engine and turbo system the oil has been changed every 800-1000 miles along with new spark plugs every 400-500 miles, not that it is required to do so often. I hate to get rid of the car, but I am in the process of starting my own High Performance Fabrication business and need the money for start up costs.
The Modifications are as follows
Engine: D16Z6
Eagle Connecting Rods
Supertech Forged Pistons (.5 MM Overbore)
Polished stock crank
ACL Bearings
Comp Cams stage II Turbo Cam
Comp Cams Valve Springs
Balanced Rotating Assembly
Block Notched for Rods
ARP Headstuds
Heavily Ported and Polished Head
Radius Valve Job
Skunk2 Intake manifold
New OEM Water Pump, Timing Belt, and Tensioner
New Oem Oil Pump
New OEM Gaskets, Including Headgasket
New Rebuilt Distributor
New Alternator
New Starter
JAZ PCV Catch can
Turbo System
Evo III Big 16G Turbo
CC-Fab Stainless Mini Ram Manifold
Evo III O2 Housing
TG Fabrication 3" Down Pipe
Front Mount Intercooler
Greddy Type S Blow Off Valve
2.5" Mild Steel Charge Piping
K&N Air Filter
Reinforced Silicone Couplers and T Bolt Clamps Throughout
Braided Oil Lines
Oil Restrictor
Tuning/ Fuel System
Hondata S300
P28 ECU
AEM Wideband O2 Sensor and Gauge
GM 3 Bar Map Sensor
Precision 780cc Injectors
Tuned By TG Fabrication
Drivetrain: D16Y5
Clutch Specialties Sprung Hub 6 Puck
New OEM Axles
New OEM Wheel Bearings
Skunk2 Short Shifter
Skunk2 Shift Knob
Suspension/ Wheels
Flat Black 15x7 Rota Slipstreams
225/50/15 BFG Drag Radials on Front of Car (Less than 1000 miles, Like new)
225/45/15 Hankook Ventus RS2 on Rear of Car (Less than 1000 miles, Like new)
Skunk2 Coilovers
KYB 8/4 Way Adjustable Struts
Omnipower Lower Control Arms
SPC Front and Rear Camber Kits
New Upper and Lower Ball Joints
New Tie Rod Ends
Brakes
11" Front Rotor kit
Integra GSR Calipers
Misc.
Apexi Black Turbo Timer
OEM Antenna Block Off Plate
Black Housing Headlights
Grillcraft Grill
Alpine Type S Speakers Throughout
Alpine Head Unit (Missing Face Plate)
Scroth Racing Harness on Drivers Side
Golden Eagle Vacuum Manifold
VDO Boost Gauge
VDO EGT Gauge
VDO Oil Pressure Gauge
Hallman ES Boost Controller
somejaykid
i'm a mod now
BOOST for the win
SickEk
yep if i had extra money to finish my build i would of but i got bills and a family so i couldnt do that man. instead i sold my 98 ek and bought this one.
got traction
i rock the sohc
there is no way that made 300 on 10psi. period
SickEk
i already said that it probably doesnt have 300 with 10lbs. It was just what i was told. and for some reason you keep bringing it up like u forgot i said it. The car with 15lbs of boost is over 300hp. Is that ok or are you going to call bullshit on that to? I have no problem backing that claim up. When I go to track ill give you times with what boost and so on. For the dyno I dont have money or place to go dyno around my house so youll have to live without a dyno sheet for a few.
98wickedcivic
No Roger i got a place we can take it too dyno. some people dont belive it because they dont have it. theres always going to be haters. I will even help pitch in on the dyno. To shut some ppl up. i will make plans for it.
got traction
i rock the sohc
how do you know for a fact that its over 300 at 15psi if you dont have a dyno?
SickEk
yep that is it. whats the big deal anyway?? if it aint 300 with 30lbs so be it. I got a wife a kid and I love this car whether i bought it built or not. thats the problem with every forum. always someone hating. if u built urs congrats. i dont have time or money. but i wont hate on you and keep startign s**t for no reason. when i get on here it is to look at classifieds and to read up on posts and just learn new stuff every day. i dont criticize cuz it aint my s**t and my place to be doing so. i think it is time to grow up and let it go cuz i drive my car every day and i have fun. i aint out to prove a damn thing or to make a point. i like it and i bought it with my money so leave it at that
