'98 Civic DX.... Sale or part out
Brewster
This is what you should try before you consider replacing the transmission, which probably has the original old factory Honda ATF in it:
  1. Buy 9 bottles of this - http://www.valvoline.com/products/brands/maxlife/automatic-transmission-fluid/37 - I have found this ATF at Walmart for about $3 per quart.
  2. Drain the old ATF from your transmission and refill with about 2.9 quarts of fresh ATF.
  3. Start engine and slowly move the transmission through all the gears (P, R, N, D4, D3, D2), pausing briefly at each gear. Do this several times. Turn engine off.
  4. Repeat the ATF drain and refill cycle (steps 2-3) two more times.
  5. Check whether the transmission now shifts gears without slipping.
Sorry to bring back such an old thread, but I need advice. I recently acquired a 2002 acura RSX. Car runs and shifts fine. Just has a stumble at times in 5th gear under 2000 rpm's. When it does this and i press the gas, it downshifts as it should and goes away. It even stops this if it hits 2000 rpm. I repeat, it only shudders/stumbles like this in 5th gear under 2000 rpm. Other than that it drives fine. I know it's an "acura" but still made by Honda. Could I use the max life fluid to do a drain and refill on this tranny or do I need to go with OEM Honda ATF? Thanks in advance.
