what should i know before i go ahead and get started with the turbo setup fo rmy car , any pointers its a 99 civic ex d16 vtec with 100,064 miles on it
92 4DoorSleeper said:what do you want to know
Yeah if you have a POS ebay one. A good block gaurd is great investment. I providing the cylinder wallwith the stability of a sleved motor. & if you saying have a block gaurd is bad the the same would appile for a sleeved motor since coolent flows though it the same.Ravage70 said:get a conversion harness and a p28 so u can run uber
and when its time for inspection bust out ur old obd2 ecu
ps blockguards create heat spots...
92 4DoorSleeper said:Yeah if you have a POS ebay one. A good block gaurd is great investment. I providing the cylinder wallwith the stability of a sleved motor. & if you saying have a block gaurd is bad the the same would appile for a sleeved motor since coolent flows though it the same.
explain to me how it doesnt benifit anything, cuz right now you are incorrectRavage70 said:no it wouldnt
a block guard is something not needed and definately not the same as a closed deck.
