thats sick s**t ...
I also installed my own Field's VTEC Controller, and did the "Glowing Redline and Si Logo" trick... here's pics of the finished product...element_323 said:Muy bueno!!!! You saved a couple hundred dollars there bro. Looks excellent! As I was reading your first post I saw that chapstick was involved I was like WTF? Very good DIY.
It's on the Honda-Tech link...FhCRubarb said:is it just me cause im not seeing the how to on the valve cover.
I used fresh Hondabond from Honda @$15.00 a tube on the eight cam corners... as per the Helm's Manual! The VC Gasket was reused... but when I do my cams and timing belt this weekend, the new one I purchased will go on!! No leaks so far... and I drove 100 miles today!!! Work is far when I have to drive... good thing I'm on a vanpool! Just use a Inch Pound Torque Wrench on the bolts... 7.2 ft. lbs means 7.2 ft.lbs!!! I broke the right bottom one in the corner, and had to Super Glue it back on until the new stud comes in tomorrow! I suck, I know... but live and learn!!!FhCRubarb said:So the valve cover unscrews and then screws right back on just like that? No sealing problems?
Download the Helm's here...Kjeldor said:blustreek99 so its 7.2 ft lbs of torque on the vc bolts, and are u gonna adjust ur valves when u do ur cams? if so do u know what the torque specs for the adjuster nut is when u do the valve adjustment? am gonna paint my vc as well and do the valve adjustment so i want to know before hand
thanx
thanx, it says on the second link that the locknut has to be torqued down to 14 ft lbs of torque, that was mainly my question, guess i didnt relly know how to explain it, but i got my answer anyways, thanx for both linksblustreek99 said:Download the Helm's here...
Helm's Download Link
Follow the instructions to get it on your PC. Ijust read it, and it says to just tighten it securely with the adjusting wrech. I just bought a 10mm long wrench from Sear's for $2.99, and heat bended it at work in the shape that allows it to fit in the adjuster. Don't go balls out on it... just snug! I will DEFINATELY do an adjustment on the valves, even though the specs are the same for the ITR and Si!!
Intake: 0.006 in. - 0.007 in.
Exhaust: 0.007 in. - 0.008 in.
Here's a link with GREAT instructions... as well as a pic of the $35.00 - $40.00 saving create-a-tool! They have the instructions of the cam install I'll do, too! Great write-ups, and pics... can't beat that! Just use the Helm's and this site, and you'll be ok... Make sure you're @ TDC and TAKE YOUR TIME!!!
Valve Adjustment Site Link
Right on, bro!! N E Time. I use the Helm's and the Internet on a daily basis... It's saved me MILLIONS on Labor Fees and such!!! You can do pretty much N E Thing, as long as you're confident and take your time!!! Take it easy, and thanks every1 for all the feedback!!!Kjeldor said:thanx, it says on the second link that the locknut has to be torqued down to 14 ft lbs of torque, that was mainly my question, guess i didnt relly know how to explain it, but i got my answer anyways, thanx for both links
