DevilDog89
If I installed a new 7.5 amp fuse and it immediately blew like the first two, would I not then still measure battery voltage on one side and 0 volts on the other? I should have battery power from the battery across the fuse to the appropriate pin in the relay socket assuming the fuse is good.
What would that mean besides the fuse being blown? I just suck at finding Waldo cause idk what else that should lead me to. If there is battery power on one side then that side of the circuit is good. If 12.5 volts on one side of the fuse is not present on the other side of the fuse then either the fuse is blown or what? Is that side of the fuse possibly grounded, leading the voltage to that ground?What does it mean if one tab reads battery voltage and the other reads ~0V?
If this happens, what is almost surely the problem?
The answer should look like a huge Waldo on a small white piece of paper.
