xenoicity said:
im really not sure what kind of resistors i used, because i just ordered the ones that came with my led's from oznium. but normally u need 1 resistor per led unless u are wiring them in a series, the thing is, and i learned this the hard way, if u dont use a resistor on a led, it burns out the led real quick
ive had cases where i didnt attach a resistor and it blew the top of the led right off. radio shack has resistors.
check this out
http://www.oznium.com/forum/topic20
I dunno if mine burned out cuz i didnt use a resonator the bulbs look fine and the wire doesnt look burned. Just what smoked yesterday is the onboard switch they have. But still when its put onto on or to beat to music mode the red or green lights on the switch work
so according to those diagrams i need a resistor but they dont have my circuit
Heres a POS drawing of my circuit:
Currently the Cathodes only work
If you can express your explanation in drawing too that would be helpful to figure it out
Also the onboard circuit on the LED's is right next to my shifter not around my fuse box where my other switch is. If you guys can help me wire it so that all the lights are controled by the switch on the LED's that would be great..
SO i want to kno how to fix the current setup to make it work
and
How to rewire it to make the switch on the led's control everything. In this case if i get pulled over since its right next to the shifter i dont need to make many movements to turn it off. its easier in a bad situation
SO i want to kno 2 different ways to make it work
