Amp Placement
96greencivic
#1 in the Atlantic!
BlackMagyk said:
tru i think im gonna go putting it under the seat. Thanx everybody
I wish I could've done that. My amp is too big for that.
that VERBAL
AKA Theiven Stealberg
EXSpeedAddict said:
i'll believe that when i see it... :roll: and disconnecting the amp isn't hard...just 3 wires to disconnect. all you need is a screwdriver...
:lol:well it is true, it won't be a big problem if you don't have big spl....but if you are pushing any semi large numbers it isn't a good idea, common sense will tell you that. I would never push something like W7s with the amp mounted on the box, in the long run it WILL shorten the life of you amp.
96greencivic
#1 in the Atlantic!
It's not hard, but damn inconveinent. It can't be good for your wiring either taking them on/off.
mercuryrising
also you have to make sure tou like tape up the ends or put a wire cap on so you dont get power...still nconvient if you just need to ring soemthing somewhere.
cujo613
hes right. the box is the worst place to mount it. Might as well toss your amp in the fryer for a while
Iakona
RaleighBoy
Does anyone happen to have any pictures of their amp placements?
1999stockaccord
Honduh's... LULZ
Heres mine: on the side wall of my accords trunk:
My old setup in the civic was just mounted to the trunk floor.
Slick_99
RIP 99'
Usually under seat placement is reserved for interior amp speakers. Just .02
Iakona
RaleighBoy
I have a 4 channel amp and i was curious where i should mount it and how? I told my dad back of the rear seats so in the trunk... and he said you cant just screw it into the seat cause you might 'impale' some one but i think the seat is thick enough... ?
1999stockaccord
Honduh's... LULZ
you can screw it right to the back of the seat, just use shorter screws..
never hurts to put some MDF under the carpetin on the back of the seat, that will also give you some space to run/hide wires
Iakona
RaleighBoy
alrite thanks man. and if anyone has more pictures feel free to post, i wanna see what under the seat looks like?
J32a2OwnsU
Resident Old Man
that VERBAL said:
Mounting the amp on the sub box is not a good idea. The vibrations from the subwoofers can shake and loosen the capacitors and s**t inside the amp.
WERD......
Mount it to the back of the backseat in your trunk.....
hondagod98
VERY common misconception.... - really depends on the material the box is made of and if the box is correctly built - i don't know of ANY sub that will make 3/4" MDF flex enough to do any kind of damage to an amplifier mounted on the box itself.... now about the easy to steal point - that is true....
J32a2OwnsU
Resident Old Man
Verbal, if I may...............
Its not the point that it 'flexes' too much, its the vibration that goes through it when its essentially mounted to the baffle. Now if oyu mount it on gromets or something, that might be better. But it still tranmits enough vibration to possibly do damage. =)
Billy.
Has returned ;-)
best amp location is ontop the roof, good air flow keeps it cool. tricky part is drillin the holes through the roof and headliner but its worth it IMO, ;)
1999stockaccord
Honduh's... LULZ
:rolf: :rolf: :rolf:
