Just a quick question im considering swaping a EG SiR B16 into my CX hatch im buying the whole clip will this be a mostly plug and play swap with minor fab work and little wiring harness alterations or am i gonna be like F*CK the whole time?
use the harness that came with the motor.....then look at a place called locash racing.....they make ecu subharness that work like butterSPONSOREDCRX said:so any b-series axles will work? trying to swap a 00 gsr into a 95 cx. i was told i would need a 95 gsr harness to plug into the stock harness, then just wire up vtec to the p72. is this right?
Thanks,
Brandon
no. only 92's are prewired for vtec.92civicboost said:Ok *ALL* EG8's are prewired for v tec but not the knock sensor you have to run that in all 92-95's
eg8s are 92-9592civicboost said:yeah thats what i mean only 92 eg8* are prewired for v tec
