b16a stock on boost?
TiiM iiS l3eAsT
Scamming Piece Of s**t
majorahole said:
thats like winning the special olympics, you may have won, but your still a retard
btw your ringlands most likley went because of your pcv system, thats the reason most do
wow like that ones any new:roll: :word:
TiiM iiS l3eAsT
look for vitara pistons....i think there pretty cheap and reliable
Steven.
Formally Green 91
for a B series?
btw, nippon is junk
Steven.
Formally Green 91
Chaos said:
do they not sell them for B series? i just assumed they would?
B series=81mm bore
D series=75
Vitara 75mm
Vitaras are from a Suzuki Vitara
its not a aftermarket company, its a OEM suzuki part lol there not forged pistons there cast
Steven.
Formally Green 91
Chaos said:
oooo lol...well i learned something new today:thumbup:
if you put them in a DOHC zc, you will have
DOHC ZC with Vitaras and .048 HG
7.054190541241936:1
Steven.
Formally Green 91
ill be gettin 9.5:1 CR pistons for a D16a6, it will make the ZC have around 9.1:1
Steven.
Formally Green 91
i figured i only want/need to lower my CR a little bit for higher boost.
10psi(thats what your goign to run right?) stock CR should be fine
civic98turbo
I'm back ....
b16a stock blocks have seen 550 hp and lived to rev .....you'll be fine....get a good tune......and be gentle
DAF
Zinc Member
--<EM1>-- said:
okok lets stop fighting and back to the thread objective.
to answer your question. yes of course you can run 10-12 psi on stock rebuild but only with a great tune. in my situation im running 12psi on complete stock with 100k on the motorwith a great tuned chipped p28 with hondata s200. just dont drive hard, and treat your motor well with lots of oil changes and regular tune ups. but i would strongly recommend to upgrade anyway since youre going to rebuild. rebuilding with aftermarket quality parts will cost just alittle more than oem, but nothign to break the bank.
another thing you should think about is compression ratio. lowering the engines comp ratio will allow you to run higher psi. but when boosting, whp is the goal, not psi.
+1, you lower your compression to basicly make it safer to boost. I would recomend either building yoru block if you want to run that much boost at 10.2:1 (or 10.4:1 if you have the JDM pistons) or getting some lower compression pistons to be safe. You may loose a little bit of HP, but it will be you will kick your self in the ass if you dont and you blow your engine on the highway.
DAF
Zinc Member
Green 91 said:
B series=81mm bore
D series=75
Vitara 75mm
b20b/Z = 84mm
cuzzfolk99
ok im getting the forged pistons and rods and a chipped ecu with crom for my b16 also headstuds and blockguard. does anyone out there know if putting gsr cams in the b16 head works well??
Kingjames83
your gonna pay just as much for GSR cams then you would for some aftermarket cams... true going for turbo spec cams, they are made to be more efficient with turbo applications
