ive got a gsr, with a built bottom end minus sleeves. im using a gt35r and stopping around 400whp or so and calling it a day. but at this point, a GREAT tune is a must. im going to jeff evans in PA for a neptune tune. the thing you will have to watch is making sure you have perfect piston to cylinder wall clearance and zero detonation. you might wanna look into a water/alcohol/methanol injection to help reduce detonation and as extra peace of mind. 400+whp has been done many many times on gsr's, so IF stock LS sleeves are the same, then you should be good with a good tune
