EM1_nic
So i had my car not moving for the winter in the driveway since november. Id start it from time to time and let it sit on idle for 10-20 mins until it was at peak temp then close it. never had a problem till yesterday, i do same thing as usual and everything is fine but i decide to rev it once its at its peak temp, revved it to 3k 3 times and once to 5.5k rpm let it sit for couple mins then shut car off and everything was fine. 5 minutes later i turn it back on and it bucks and idle is fluctuating(200-1.3k rpm) and car shakes a bit and is really really rough, it also has no CEL. I let it sit there for the night and started it again the next day and everything is fine till the idle drops at lower rpms then it bucks again and runs very rough. Haven't tried driving with it as i have no clue why it does this. could the revving have broken something even though it was at its peak temp? I need help the car was running great since i have swapped it a year ago. no CEL light on and everything was running fine until i turned it off and back on....
info on car: stock block b18cr, only mods are I/H/E, stock p73 obd2a ecu
