how much does it usually cost to get a lip painted in a shop?
Go to Strauss auto and by some adhesion promotor. You spray it on just like primer. It's kinda like a clear primer. Good luck. Def try to paint small things. You'll get better at it.chimchim said:Also... I bought some paint matched spray paint at Kragen. The guy had no idea what primer would be need for ABS plastic (he'd never heard of it), as primer is mostly for metal. He said to paint directly on the plastic.
Should I use a primer first? If so, what kind?
Question, If the lip is just a bit off and easily bent, do i still need to do your heat gun trick? Or can the primer or paint take the little bit of flex?ljnick17 said:don't get that pissed that it didn't fit perfect, because NOTHING fits like oem. you usually have to do at least a little modification to get things to fit. as for making it fit, you could try heating it. my local bodyshop has done a few bodykits, both urethane and fiberglass. for the plastic stuff, sometimes you can achieve the bend/shape you want by heating it slightly with a heat gun, and then bending it to the desired form and holding it until it cools off. don't heat it too much though, just enough to where it is pliable, because it is plastic, so it can melt. and of course, if you do this, do it before any paint/prep work.
