Electronic Load detector in the fusebox thats under the hood. it controls the charging systemEld?
from what im reading, it might be built into the fusebox. so to test it isnt going to be as easy as it was for meDo egs have it?
Oh boy....from what im reading, it might be built into the fusebox. so to test it isnt going to be as easy as it was for me
Yeah that's the fuse that keeps popping when I tap the ground on the alt.have you checked fuse 12, 15a, in car fuse box. is in circuit with alternator and eld, and im not sure totally what your issue is but just giving out some ideas that could cause the problem. electrical issues can be quite the b***h
tapping a ground can cause power surgesYeah that's the fuse that keeps popping when I tap the ground on the alt.
Hmm.tapping a ground can cause power surges
