Good question, i had the smallest of openings in my injector wiring harness and moisture got it. it made the car run all jacked up. anyway alot is to be said for spending the money on proper electrical connections. my 2ccheck your wiring because you might have a wire shorting on something metal such as a bracket
did you tape up your fuel injector wiring good?
pump wiring? I was able to pretty much take the stock pump out and put the new one in with no problems. I had to made a few adjustments to get it to fit, etc... but didn't need to do any wiring.have you checked your fuel pump wiring yet?
sorry for the delay. i run mine over the manifold. i know its not the cleanst look but, it helps me make sure everything is the way its supposed to be. any luck trouble shooting that short?I did tape them up good, and wire loomed them.. however they do run under the manifold rather than on top because it looks cleaner. I will check for shorts in the wiring..
Would fuse 15 just randomly blow once due to some overload?
