a B18C5 with a GReddy TD05-18G turbo kit (running at stock PSI) would perform nicely and be reliable. when you start to get power hungry and want to up the boost, thats where you can run into problems. with a typeR, you'd want to concentrate on all custom internals to drop that compression rate, so you can up the boost safely. Most peeps prefer a GSR or LS motor for boost because its already lower compression. Something that people dont look at is, the fact that the typeR comes with a lot of better and more powerful parts inside it which helps it to put out better numbers in the end than a GSR. (but thats only because the builder doesn't pay that close of attention, or reaches their power goal without upgrading those parts)
it doesn't matter too much about which motor you build for turbo.....as long as you hit every detail and do it right, you'll make insane power.
