Hi I just got my 94' hatch w/ an ls turbo running and everything is good as far as turbo kit but when i started it for the first time last night (in like 2 months) it has a nasty miss fire, so I changed the plugs and switched chips and it still doing the same thing, I dont think if its a boost leak because it runs perfect when you rev it up a little bit the miss goes right away... It drives pretty good even, it just has a low sluggish idle (600). Its been a couple days and I cant figure it out now?? Any ideas or thoughts would help me in advance. Maybe its just cause its untuned (im running a base map chip) or cause I tapped my vacum off the brake booster?? I just dont know
\ Its a b18b1 with a ported MHI 16g turbo, fpr, walbro 255 pump, rc440 injectors, 3"exhaust, 9psi
