Rarely will you find a used block that won't have too much wall clearance on 81mm pistons. You might be able to hone and use 81.08mm pistons. You can bore stock sleeves to 82mm but wouldn't recommend going pas 81.5mm for a FI build. Heck, if you've got the $$ get it sleeved.why are you wantin to make you cylinder walls thinner? if your runnin boost you would want it as thick as possible. why not trade someone for some stock bore pistons?
