LongGrain said:
more like going from an f22a to a B16...even tho its less displacement. it can still be a better motor. and as for the KA having a bulletproof block. their pretty strong. but the CA is still cast iron and with good pistons will take anything you throw at it. and like i said. getting a ka24de would be pretty difficult for me, CA18 is very easy. honestly i would take either.
especially over my single cam piece of crap with an auto tranny..
Single cams can be beasts as well, they are actually stronger then the DE is, believe it or not.... However, you are still only running single cam, so you are a little bit limited....
Yeah, the CAs are abuse junkies.... If you put just a little bit of work into them they can withstand crazy amounts of boost without a single hiccup.... Most people's problems is that when they buy one they don't rebuild it when they get it, rather swap it straight in.... CAs are generally older motors with some abuse in them, if you want to avoid problems take the time to rebuild it before you swap, you'll be thankfull you did....
But all that is null and void because the RB is the hotness....
